73-74 RoadRunner hoods
both are "Beep Beep" horns. I guess its possible someone added the one on the passenger side and since the wiring harness is the same for Satellite, which used dual horns, that may make sense.
So that's why I have squirters on the hood and the wipers.
I've been thinking about setting up a secondary washer syatem and pointing the hood nozzles way high so they shoot over the car and splash tailgaters :icon_fU:
thanks funnay!
someone else mentioned two beep beep horns that had been adjusted so one had a higher and other had a lower note
can we get an mp3 or vid to hear your dual horns?
Unfortunately, my car is still under construction, but i hope to have it back together this summer. All i know is that having two horns, its loud as hell, and actually have scared some people when i honked it! LOL
74 hood ??
Yes, 73's have canister, here are a couple of shots of mine before i took it all apart. The AC line is on top of it and none of the vent lines are connected.
Did someone say they are looking for a 74 hood? I have one.
Does it have scoops ?
Do you still have it ??
:eusa_clap:
gottapic?
Mike..
Just to throw a curve-ball into this discussion, why does my 74 RR have the cut-out, in the under-hood re-inforcement, that an air-grabber from 71-2 would have?
