73 Charger 8.25 rebuild bearing issues??
jvamato
New Member
7:16 PM
pittsburgh
I’m rebuilding and upgrading the 8.25 diff on my charger. Using 3.55 Richmond gears and a limited slip carrier. I ordered a spicer rebuild kit that came with pinion and side bearings. Pinion bearings are a perfect match but outer diameter of side bearings is bigger. Most of the bearings I have looked up have the same dimensions as the ones that came in my kit. I ordered the bearing part number I took off. Has anyone seen this?
