73 Dodge Charger SE Big Block Motor Mounts Where to Buy
garyinmich
12:21 PM
Michigan
Anyone out there know a source for 73 Charger Big Block (Spool Type) motor mounts? Any help appreciated, thanks!
Search the threads here. I believe many people have had Chinesium issues with motor mount fitment.
Look at 440 Source and Mancini. Spend the money for better parts.
I have *** U.S.A. made *** Spool Motor Mounts…..
P.M. me, as per forum rules, if interested….. Craig….
( I purposely hunted them down , and stocked up , because as Billccm notes ^^^ above ^^^ , the Chineseum mounts are frequently misaligned….. )
If you have the mounts/brackets, you can replace just the bushing and service the mounts. Don’t need a full mount replacement.
Have you ever replaced the bushing? Any special tools required?
Never have needed to replace them because I found a NOS set of mounts set dirty cheap locally in Venezuela 15 years ago, but they are really serviceable and not hard to do for any semi-competent mechanic or shop.
NOS Mopar show up on ebay quite often for under $100 for a pair.
On this case NOS parts are not a guarantee of good conditions or really able to last long talking about rubber parts.
I am restoring a 74 right now. The majority of the original rubber suspension parts are still serviceable at 50 years old. Modern rubber breaks down in a stupid amount of time. I would trust a 50 year old factory NOS part way more then the current offerings.
10 years ago I bought poly mounts for my 73 from Mancini and they're still in good condition......this in a car that goes 10.65 in the quarter with a 5000 stall converter and 10.5 inch slicks.
I like and use poly parts where available. Modern rubber though leaves a lot to be desired.
Not saying it won’t work, but just not a guarantee. Depending on storage conditions
Thanks to you and everyone else for the input. I will probably just replace the inserts.
