73Beep
New Member
Trying to see if anyone else has run across this issue. Factory a/c control. Blower functions on all speeds with knob in max a/c, a/c, and vent. As soon as you click to heat or defrost, the blower shuts off. I did check the resistor, even though all the speeds are present on the a/c & vent positions. The resistor is ok. I believe the issue is in the control but I do not have a diagram available. It just shows the low, med, & high circuits. Any guidance would be appreciated.
