74' satelite front sway bar
KCCOcolo13
New Member
1:35 PM
Penrose, Colorado
I'm building a race car out of a 1974 satellite and it does not have a front sway bar. I'm going to head to the junk yard and try to find one. Just wondering what other b-body's had the same sway bars. Just in case I can't find any satellite's. My K member has the holes so the sway bar can pass through it. Not too worried about stock mounts on the lower control arms, I can fabricate those. So if anyone has any ideas that will be great.
Thanks Bryan.
73-79 Satellite, Charger, Coronet, Cordoba, Fury (75 and up), Magnum.
I just found out not all cars had sway bar mounts on the K frame (mine doesn't).
The outer ends clamp to the strut rods, so no LCA tab used.
Also bars were different thickness depending on small block or big block.
