What is a bundle? Educate me, please.
What is your budget? 2k max.
Honing, yes. Boring maybe yes as a standard size pistion appears to be rair??? This low compression 1978 engine alleged to have twenty five K on it. I think this maybe true as there is no sign of ring ridge. and it did come from a motorhome.
Machine shop? Yes cam bearing installation. Measure cylinder size to see if machining is needed.
I'm pretty sure this is the piston needed.
https://www.summitracing.com/parts/uem-kb184-040/warnings/
However, it looks like they may be required to be machined for clearance.
"Due to the multiple variables possible with any engine combination, all compression ratios listed are approximate. To accurately calculate the static compression ratio of any engine, the following values must be known: Bore diameter, stroke length, rod length, deck height, combustion chamber volume, cylinder head gasket compressed thickness, and cylinder head gasket bore diameter."
Starting appear to be a can of worms. Pipe dream at this point. Just might go rings and bearings and call it a learing experience.
Many thanks.
