BSB67
Based on what I think I'm hearing from the OP, that is what I would do with that kind of budget. Bearings, rings and 75 cc Eddy heads, or similar. Way better hp/$ than screwing around with pistons.
For 2k it isn't a debate for pistons or heads, neither are on the table at that budget level.
Hone it yourself, re-ring it, new bearings, gaskets, and valve stem seals to start with.
Next is bolt-ons: Headers, cam & lifter kit, car oil pan & pickup, used aluminum intake, carb, and air-cleaner. Just the basics will eat up that 2k budget quick!
Pretty good advice. If Auggie56 has the time to read through this thread he may find some useful information.
https://www.forabodiesonly.com/mopar/threads/dyno-testing-a-stock-1972-440.249866/
Maybe even this will help. As above, if you don't have the budget the low compression doesn't have to kill power.
https://www.forbbodiesonly.com/moparforum/threads/the-slug-400-on-the-dyno.80843/#post-910150902
low compression
short duration high lift cam with as much area under the lift curve as possible
get the intake closed early to trap dynamic compression
open the exhaust late to get as much power out as possible
intake valve open as much as possible from max piston acceleration (around 70 ATDC) as long as possible
bigger duration cam then the more converter and gear required and soon the heads cannot keep up with the cam so no more top end and you've lost the bottom end
try and afford the kb pop up quench pistons but if not stay conservative
not to say not to run a big cam- we did it in class racing but motor never saw below torque peak
