great idea.good job with this.I had a 1979 Aspen R/T (F-body) w/E58 option Police 360. The 8 1/4 2.72 rear end didn't help it's performance..I bought a 4 speed 73 340 Dart from a junkyard (yeah, I know) and the 8 3/4 housing and axles-everything as an assembly bolted right in to the F body! Even the pins on the perches lined up with the holes in the leaf springs. I later swapped in a chunk from a Charger when the ring and pinion gear broke. I just had to get a "2-way" U-joint to match up the driveshaft's smaller caps and the chunk's larger ones.
The point is that the 73 A-body 8 3/4 fit the 79 F-body with no modifications.
Thanks. I signed up on the F-bodies forum and my recounting of that story was met with some controversy, but it happened exactly the way I posted. Seems like they think that 73 A bodies had 8.25 rear axles, but I'm pretty sure it was a 73 Dart Sport, and I am certain that it had a 340. Seemed all original to me. I don't recall how I got the aluminum Aspen R/T wheels to fit the bolt pattern which they rightly say is smaller than the F body (which is the same as the B body). The rear end swap was definitely a straight up bolt in, THAT I am sure of.great idea.good job with this.
Can we get the "good" axle measurement chart as a sticky?
The one that has the correct numbers for the 66/67 axles?
I can never seem to find it when I need it.
