furyus63
Matthon, I did not see the make or year of your car. From your photo is your car a 1963 Plymouth Fury Station Wagon. If so I may be able to provide some information on how I corrected the same problem on my '63 Fury.
1964 Fury wagon.is your car a 1963 Plymouth Fury Station Wagon.
Not this time.And did you repack the axle bearings with grease?
No, with what exactly?Did you lube up the threads?
Adding lubricant changes the torque value. I guess not having a torque wrench that goes high enough. they say to reduce the torque by 25% when using Lubricant during torque.Engine oil would work. I torqued mine to 150, and then added some with my 1" drive ratchet. In your case since all the parts are the same, tightening up to the same marks should work, but a little oil would make it easier.
