memeep
8 3/4,,, 70 rr installed green bearings,, driver side axle is bottoms out in the carrier,,, before the bearing flange does on the housing by 1/4 inch!! Is the bearing pressed on the axle too far???
I think that there is a "step" in the axle shaft to locate the bearing.
It should just push out. You're right if you convert to green bearings you have to remove the spacer in the center of the carrier where the axles meet.
This would depend on if its cone or clutch type how it comes out.
OK thanks,,,, I have a metal band saw that cuts cool.and slow!! I may try that or just take it apart,,,, once again thanks for your help and time!!!
OKim taking it out today but when I reassemble it does it havea gasket or do I use some rtv sealant??
