Thats not all the ratios. Cause I have a set of 6.14 gears for 8 3/4Gear ratios available on the 8-3/4" axle through the years include: 2.76, 2.93, 3.23, 3.31, 3.55, 3.73, 3.91, 4.10, 4.56, 4.89, 5.17, 5.57.
http://www.mymopar.com/Mopar8_75RearEndGuide.htm
As a highway cruiser, I have to observe the speed limit of 75mph but when there is no police I may want to satisfy my soul by going as high as 150:headbang: but actually, I am thinking of the 512CID stroker motor along with the highest gear to achieve reasonable millage. I would like to see the monster rev around 2500 @ 75mph.Hi Pouria, may I ask what speed you are wanting to approach and sustain regularly?
Yes I am from Tehran. The fuel is 1.15$/US Gallon, seems very cheap but the average income here is less than 400$! Yes, using tall tires would be another consideration to increase the final ratio and I would like to use 16" wheels. Maybe 245/40-16 would be my choice.Pouria, I see that you are from Tehran. Just curious, how much does fuel cost over there? One idea would be to use the 2.76's and fit the largest diameter tire that you could find. I'm running 30" Mickey Thompson ET Streets; the tall tire makes my 4.10 gears feel a bit more like 3.91's or maybe even into the 3.80's.
a 2.76 gear with a 28" tall tire is 75mph at 2500rpm.As a highway cruiser, I have to observe the speed limit of 75mph but when there is no police I may want to satisfy my soul by going as high as 150:headbang: but actually, I am thinking of the 512CID stroker motor along with the highest gear to achieve reasonable millage. I would like to see the monster rev around 2500 @ 75mph.
I'll love it then.a 2.76 gear with a 28" tall tire is 75mph at 2500rpm.
I'll love it then.
Thank you all for the useful info. Now, how can I tell my own gear? How should I know if I have a sure-grip or not? It is the original gear of my 1973 Charger 340 Rallye with 727.
Another question is, how strong are the stock gears? Can a 2.76 gear handle the high pressure of a 512 stroker motor? What about the trany? my 727 has already been swapped with an A833 out of a 70 Challenger. By the setup I am planning to build, I have a high toque motor at one end and a high gear at the other end that doesn't let the car start moving easily. Everything in between will be under extreme pressure and load, could that make any problem?
Wooow, I didn't know that! I try this next time I go to the garage and post the result!Jack up the rear so the wheels are off the ground. Start spinning one of the wheels if both wheels start spinning the same direction you have a sure grip if they spin opposite directions you have a one legger.
If it's a stock rear which I assume, you'll want aftermarket internals.
