Light car and braced. High ratios have lots of pinion teeth. How many passes? My sons 3750lb turbo car sheared the 8 3/4 pinion shaft at 16lbs boost. Today my buddy Mike took his 64 Polara out for it's 1st outing with the new 735 HP power plant. Not only does it need a rear axle assy. The trans is toast, rare 65 case to boot. It broke an ear of his Hemi block. Still want to chance an 8 3/4 with big power and a heavy car?It weighed 3000 lbs. The housing was braced. The ratio was 3.91 for some of the time but mostly used 3.23. 742 case.
Turbocharged 5.7. Trans brake too.
1.23 60 foot
Doug
Doug
Seems to me the problem with zero backlash is the thermal expansion of parts. That is going in multiple directions.
Thermal expansion happens and the parts -all- expand due to the increase in temp but maintain their relative proximity to each other. (expansion is not random).
The difference in size from cold to hot depends on how much temp. difference happens. I'm not sure what would be considered a very hot rear end in operation but I suspect that 150 degrees would be considered rather hot for a differential.
So (for example) a cold temp. of 70 degrees to 150 degrees is a rise of 75 degrees.
A one-inch long piece of steel will get longer by about .00045 Inches. (less than a half of a thousandth of an inch.) @ 225 degrees the expansion would still be less than one-thousandth of an inch. (.0009")
As everything in the differential expands, --in the same way,-- the change in backlash is affected as well but the amount is very slight in reality.
The ring gear will get bigger but so will the pinion. The whole unit will swell up a bit.
For an illustration example-- let's say the axial shafts got hot and therefore longer.
That would overload the wheel bearings (which are basically set close to zero).
Since the housing also gets hot the same amount of wheel bearing running clearance is not affected.
The real problem with zero backlash is there is no easy way for oil to get to where it needs to be. It has to be forced to do so and that takes energy which translates to heat.
I agree the oil clearance is a major factor. Not all the parts expand in the same direction, some are more fixed than others. Seems to me the ring gear is expanding toward the pinion teeth, the pinion teeth are expanding toward the ring gear. Granted with steel the change is minimal, but I wouldn't do zero.
I've found factory pinion bearings as tight as .005" before! That's toooo tight. There is a chart for bearing to shaft fits for all the different diameters but can't remember exactly what it is....but have never had any problems with them being .001-.002.Don't parts grow in all directions when heated? When I put a pinion bearing on, I put pinion in freezer for half hour. Then warm bearing a little (180*) it drops on. Isn't there a .002/.003 interference fit. So zero lash would grind the gears up I would think.
