Have 1966 Satellite 8.75 diff. with an open rear 742 housing. Had a 489 housing freshly setup with 4.10 gears an a clutch type sure grip. Put the 489 in and put in right axle didn't go in all the way but could put nuts on flange. Backed of adjuster until it had an 1/8" of thread showing, it won't go much more. Went to bolt flange down but when it was getting tight there was an 1/8" space between backing plate and axle flange. (Glad I wasn't using air tools) Pulled the axle out and measured end of axle to flange 26.5". Then took a piece of straight tubing and measured thrust button to flange 26.25".( These are approx. measurements it's obvious there's a problem.) The sure grip came out of a 742 housing. Should I have put an Auburn unit in? (spring type?) ARG!!! HELP!
Fran B.
Fran B.
