8.75 width
72duster72
10:01 AM
castle rock co.
i was told 68-70 the width is 55 flange to flange 65-67 does anybody know that width i was told they are narrower. how much ?
The 65 housing is the narrowest,of the b-bdy housing apx.521/2".The a-bdy 8 3/4 is the narrowest of all around 51"
More info on this thread.... http://www.forbbodiesonly.com/moparforum/showthread.php?t=10836
Axles vary a bit even out of the same car line. Tolerance wasn't held that close but I've found the 66-67's run around 5/8 to 3/4" narrower than the 68-70's and right now I have an A body housing that I'm working on, and it's 52 5/8", housing flange to flange. Most I measure are 52 and change and they all vary a little with this one being the longest to date.
my 72 a body rear is 2 inches narrower than my 66 b rear
thanx i am working on 69 road runner i want to install a little narrower rear end without custom making one or tubbing thats why 65-67 it will narrow close to 2 plus in. from what i am here from you guys
Yup.....should be closer to 2 1/2" shorter....but the spring pad width are not very much different.
