Nevada dan
I was having shifting problems before I rebuilt it and changed the lube to GL4 made a noticeable difference , that's all I'll ever use now
My 833 has about 105,000 miles on it and has never been opened and was certainly never treated with respect. Running the engine oil I have a light front seal weep that I have to fix this Winter (or at least that's what I'm praying it is and not a rear engine seal). That said 20W50 motor oil.. if it was straight weight that's a 100 weight oil when hot. Transmission has never shifted as smooth as it does now while using engine oil..Most of my 4-speed experience is with Muncie's and Toploaders and I've just recently acquired an 833 in a car - but I'm always amazed at reports of running motor oil in one of these old 4-speeds. It takes a lot of effort and care to re-seal one of those old transmissions to where it will hold in 85-90 gear oil. Motor oil in an old aluminum Muncie with a worn countershaft bore would probably be nearly dry of oil in a day or two. And my Toploader I've rebuilt/resealed a couple of times and it still has an occasional drip. I guess if you can get an 833 sealed up good and tight then go for it.
Another vote for GL4 Sta-Lube from NAPA.
Not any more. As I said there are now GL-5 gear oils for transmissions.GL-4 goes in transmissions, GL-5 is for rear axles. The shear additives in GL-5 can eat the brass syncro rings. Synthetic has never worked well for me in an a-833.
Wow, funny how upper management 'knows' what the mechanics should be doing!I worked for a Delivery company for 25 years maintaining their fleet. In the mid '90's The Upper management decided to be more environmentally friendly we should start using synthetic gear lube in our our newly rebuilt Muncie and New Process four speed transmissions. Right off the bat we began having problems, The transmissions would not shift without grinding, UNLESS you shifted very slow,,,. Now what delivery driver is going to shift slow? Within a couple of weeks the synchros were destroyed. The problem was that the old bronze synchros need a certain amount of friction to get the gear spinning and the Synthetic lube was too slick to get them up to speed. A trans would last about a month. We talked extensively about this to upper management but "they" knew better and would not listen. Every shop was sent a barrel of Syn gear oil to use and when a shop audit was done they better NOT find any regular gear oil! Soooo, when we would order a trans (we had a local trans shop rebuild all of our transmissions) The shop would send a couple of jugs of regular 80-90 that we used and then ditched the empty jugs in the dumpster....Ed
Again, there are now synthetic GL-5 gear oils designed for manual transmissions that work with the synchros. Modern chemistry is great!hell, I could run olive oil in my trans after I rebuilt it and swear to all of you it's great and eco friendly too ,but that's not going to be very good in the long run , synthetic is great for the newer stuff but its designed different and I can see using motor oil if it's so cold you have to drive a mile to get it to shift out of first gear ,but the fact is they engineered this stuff for what they had then and they lasted and functioned great
Management has to give itself a reason to be there....LOL..Wow, funny how upper management 'knows' what the mechanics should be doing!
Yep, ATF in both my '85 GLH Turbo critter as well as my '89 5.0 Mustang, both bought new.IIRC back in the late 70's they started running ATF in the manual transmissions. I was servicing new vehicles at a Dodge dealership and checking one one day I found red fluid in a three speed van and had to research what was going on. Yep, ATF.
I guess Royal Purple doesn't know anything about oil.
Their Max Gear oil has the performance of a GL-5 without being corrosive to ferrous and non ferrous metals.
Here's one from Red Line.
https://www.redlineoil.com/75w90-ns-gl-5-gear-oil
Here's one made for the A883. Notice it is a GL-5.
https://www.redlineoil.com/75w140-ns-gl-5-gear-oil
I use their "strawberry milk shake" aka Shock proof heavy gear lube in my moorsickle transmissions.
