9 1/4 Ratios
Randall Miller
1:44 PM
Findlay, Ohio
Good day. I've searched and searched and only find muddy answers.
I do 4wd stuff and 3.54 is the lowest numeric ratio available.
The question... did Mopar cars have other ratios? There's a 68 Coronet Auto Rt for sale w a 9 1/4. Says is a 3.23.
I would've thought it to be an 8 3/4 but it is a 60. Did it come w a 60 as an auto and was 3.23 a real gear back then?
Thanks. Rudy
Thanks. Rudy
some 4x4 trucks with the 9 1/4 had 3.91 and 4.10
A Dana 60 is a 9 3/4. 3.54 was lowest numerical ratio offered.
And then there's the Dana 53 9 1/4 with a 3.31... again a different animal.
@ Randall Miller, what rear do you actually have, and which direction are you trying to go?
IF you have a Mopar 9 1/4, summit has around 60 different gearsets for it, from 3.21 to 4.88 (at least) and lots in-between, including reverse rotations for front axles.
Dakotas could have 3.92. Standard on R/T.
I've heard of special a order R/T with 3.19!
Thank you. Yes. 9 3/4. I run a 4wd shop. Calling it anything but a Dana 60 is weird to me.
Chrysler only called them nine and three quarters. But I hear what you're saying.
If you're looking for numerically lower numbers, the 9.25" diffs in the 70's C-body cop cars and '75-'78 Big block B-body cop cars had 2.71s and 3.21 as options, although a limited slip was only available in the 3.21s. Then again, good luck finding a those cop car parts as they are quickly climbing in value.
my 02 Dakota has a 3:54 9 1/4......... both tires spin together, and it's tight as balls........ I'm gonna see how wide it is before any brain storming
I measured my Dakota and an 87 D100 with an 8 1/4.
The Dakota was wider!
