A/C and alternator bracket information needed
43tutor
3:38 PM
Upstate SC
I'm working to finish my restoration and need some information on the A/C brackets. Car is a 72 Satellite Sebring Plus, 400 engine, A/C car. When I bought the car it had a 440 and the A/C had been removed. I'm working to install the 400 back into the car along with the A/C. The previous owner gave me the "original brackets" but it turns out these "original brackets" have been cut, welded and screwed-up and will not fit on the 400. Needless to say they are a mess.
Does anyone have some good photos of what the original brackets look like? Anyone have a set of brackets they would sell? Or do you know where I could find the brackets?
I also need the upper alternator bracket. The bracket from the 440 seems to be too high on the upper mounting hole (pivot bolt location) and I assume this is due to the 440 having a taller deck height.
Thanks.
Here is the 70-72 BB setup. The little bracket on the front of the pass head is for 383/400, not used on 440.
