Well, since you mentioned it-
I have seen some aftermarket kits that are not as well designed as OE Chrysler systems. In a perfect world, you would have a 7-8* condenser approach. That is liquid line temp ( leaving condenser line, heading to the filter-dryer) minus entering ambient air. Here's the thing though, you need a honkin' big fan to simulate the vehicle going down the road. Temps and as a result the pressures vary with airflow.
It would be awesome if there was an EPR valve replacement for 134a. If you could regulate to a constant 33-34 psi in the evap, you could hold a nice temp. Mostly it's the "universal" kits that seem to have the most trouble. Chrysler had well designed piping/hose setups, especially 69 and later. Watch your hose routing, avoid any sharp metal that could wear a hole, exhaust manifolds, etc. Of course, lightly oil the O-rings and any aluminum threads and make sure there's no leaks.
