I’m 75 years old and still have a little bushy but in my sistom. I like to stick up to myself.Had gears like that in my LeBaron.. you could pull first gear to 60 mph. Stock 360
The car is totally stock, bumper to bumperThose need to go first thing, immediately. Get a 2.9 or 3.2 and you will not believe how much different the car is with the same engine.
what size rear tires? Taller the worse in this case.
I don’t mindYes, new aluminum or even old (915) worked over closed chamber heads and a proper cam with headers or HP cast iron manifolds should get you there, as long as your talking 4-bbl or add-on fuel injection. I would want to match up a good converter with cooler as well, if you don't mind getting a little dirty.
Thank Bob, like I said, just a little more boost will be awesome. I had a 79 RV with the Lean Burn and dropped a valve doing 60 to 70 on the freeway and it was a big mess with about the same mileage. So it’s gitting a valve job no matter what. My Mopar guy suggested 906 headsPerhaps the best thing to do to insure long term reliability for your anticipated coast to coast journey is:
1. Tune up and safety inspection and tires
2, Coolant change check hoses
3. Change engine oil snd filter
4. Change trans oil
5. Enjoy the scenery
As the car has performed adequately thus far, do nothing else....no headers, cam, heads or other engine mods to cause you possible grief along the way.......just my opinion of course......
BOB RENTON
Rv's did not run lean burn.Thank Bob, like I said, just a little more boost will be awesome. I had a 79 RV with the Lean Burn and dropped a valve doing 60 to 70 on the freeway and it was a big mess with about the same mileage. So it’s gitting a valve job no matter what. My Mopar guy suggested 906 heads
I could not find any specs on the Whiplash cam
It has been over 30 years but I could swear it was a lean burnRv's did not run lean burn.
I could not find any specs on the Whiplash cam. Most of these cams with fancy names, Bootlegger, Whiplash etc have extended exh duration & tight LSA. That creates a lot of overlap & gives a raspy exh note to make the girls look..... Worst thing possible for a low compression engine. You need to retain as much cyl pressure as possible [ already reduced because of the low comp ratio ], rather than pushing it out of the cyl with a high overlap cam. The idle quality & vac will also be considerably worse. The cam I recommended earlier, single pattern & short duration, would be best to give [a] a modest hp boost retain low speed drivability.
I'm going to have to agree with this one. My limited experience is with their smallest solid lifter BBM cam. Not the Whiplash, but also a higher lift, shorter duration cam.. I know, I know, it's in a race car. But let's look at the similarities to the OP's situation. My car is all steel (except scoop and front bumper), all factory glass, roll bar added, so still heavy. Motor is iron headed 383 (factory 915's), no port work at all. No power adders or any voo-doo whatsoever. You'd be hard pressed to convince me that this car would not be an absolute blast to drive on the street if it was running 3.90's and street tires. BTW, it matches the advice I gave in post #3, and along those lines.... if you read post #4, I'll give you three guesses who put the performance curve in the distributor for me.I am quite sure to say that Hughes knows what they are doing with their cams.
I need the haha icon that's not available. Couldn't agree more. If you're going cross country and the car runs well now, don't mess with it just before the trip. Going to higher gears now, especially when you're not used to it, will only give you a headache on a long highway drive like that, not to mention the fuel costs. Keep what you've got for now, get the maintenance in shape with fluids, filters and plugs, throw some tools and spare parts in the trunk and enjoy.How about 4.10 gears......just right for a cross country road trip......???
BOB RENTON
Truer words were never spoken.....see my #6 response.....everybody wants to change cams, heads, engine mods, steeper rear gears (3.55 and higher).....for what purpose.....to "MAKE A LITTLE MORE POWER"...which will result in higher fuel costs and reduced reliability.....where is the person going to get a replacement "whiplash" cam or equilivant, in Bumfuck Iowa or the middle of nowhere Montana, or Death Valley Arizona with 120 degree temp, when your car overheats and craps out, beside listening to the drone of the engine at 3000 RPM for 500 miles getting 12-15 MPG all day......personally, spend the $$ on first class plane tickets, first class hotel accommodations, enjoy great restraints.....go in style.....save the car mods for your "local buddies" at the car shows......but to each his own volition......I need the haha icon that's not available. Couldn't agree more. If you're going cross country and the car runs well now, don't mess with it just before the trip. Going to higher gears now, especially when you're not used to it, will only give you a headache on a long highway drive like that, not to mention the fuel costs. Keep what you've got for now, get the maintenance in shape with fluids, filters and plugs, throw some tools and spare parts in the trunk and enjoy.
