A Progression Ignition Question
Don67Satellite
1:16 AM
Abbotsford, British Columbia, Canada
Mulling over some of my winter project ideas....
For those here that are using Progression Ignition, I just had a curious question, in the wiring diagram, it shows, to my eyes, a keyed power source hooked to the positive side of the coil. In the instructions it states "The distributor will operate on a negative ground, 12 volt electrical system. It must receive full battery voltage during all operating conditions.
VERY IMPORTANT!!!"
Also the normal warning about the ballast resistor.
I am just asking where others ran this single power wire to, that will provide full battery voltage in, I assume, crank, start and run...
Thanks in advance.
Simple
Gut the Ballast Resistor , and install your jumper wire inside for a factory type look
Problem solved
What ignition coil are they recommending with that system ?
Answered my own
What kind of coil should I use?
We recommend coils with a primary resistance less than 1 ohm. Most aftermarket high performance coils are fine. The distributor will automatically adjust dwell for the coil you use. Some examples are- MSD Blaster 2, Pertronix Flamethrower 2. For more modern square coil we recommend the MSD Blaster SS or FAST i91.
@Bee1971 I currently have a fairly new MSD Blaster High Vibration coil, I believe 0.7 ohms which should be fine.
So if I gut the ballast, replace resistor with a 10AWG wire between the terminals, that will give me full 12V on the blue coil wire in start/run?
It sounds right to me, but obviously if I am asking, I'm dumb.
I put one of these on my drag car it sat all winter in climate controlled shop and would not start after setting 3 months. No spark ,power where in needed to be. Put Accel 300 + back on and fired right up. Just sayin.
Accel 300+ seems to be a generic name for a line of Accel products.
If you mean the coil I have (you didn't specify), it has so far been flawless for the past couple years, but yeah, any brand can go bad.
I would assume the ignition box itself is built into the distributor , you don’t need a separate ignition box correct
Then the Distributor itself is powered off the positive side of the coil , hence the full 12V for that very reason
So now that you added the jumper wire within the ballast resistor , during cranking the ballast resistor is bypassed and should supply cranking voltage of 12-12.5V to the positive side of coil
Run position or driving you should now have 13-13.5V at the positive side of coil depending how good your charging system is
Correct, no separate ignition box. Charging system is good. Thanks for the simple explanation. :thankyou:
**Update**
The Progression Ignition is installed and functioning properly.
Have had the car out for a couple shake down runs since doing a few upgrades over the fall months.
Really impressed with it and the ease of being able to change the timing on the fly, and of course the built-in ignition lock that disables the distributor. All crank, but no fire. Awesome theft deterrent.
Definitely happy with the purchase.
I have a progression distributor in my SBC. It has been amazing for 2 years. I just ordered one for my built 440 in my Coronet. I’m tired of taking apart to change curve. If nothing else, dial it in with progression, then mimic it with a traditional style distributor.
