A Request For Help From 2 Door Sedan Owners - Need Measurements Of Window Fuzzies/Cat Whiskers
64 Sportfury
2:09 AM
Nassau, NY
I searched without luck for widow fuzzies/cat whiskers for my 68 Dodge Coronet Station Wagon. They are available for 66 - 67 2dr. Sedans. With a few measurements, I can determine if these will fit my application with some massaging. I am looking for total length for both front and rear side window fuzzies (inner and outer appear to be the same length). If someone has a set that is unistalled, I could used the spacing on the center of the clips as well. Again both front and rear. Thanks in advance.
Hi Fury Man,
66 Coronet 2-door Sedan. Please give me a link for those fuzzies. Thanks
Front Channel Fuzzy 27.5 inches
Rear Channel Fuzzy 22.75 inches
My 66 Coronet 2 Door Sedan (waiting for snow to melt)
We make the correct window felts for the 66 to 70 B-Body wagons and the 66 to 70 B-Body four door sedans. The rear doors are slightly different between the sedan and wagon. No need to modify a set of four door sedan felts. Any of our stocking vendors that carries the Top Catwhiskers can supply them to you or you can purchase direct. The part number for the 66-70 B-Body wagon felts is 990908.
Thanks so much LSS&B for the quick and accurate response. I sent you a couple of PM's with vendors that have your application covered.
