- 10:51 PM
- May 14, 2011
- On the Ridge, TN
In this, the next chapter of my infamous "mystery motor" 440 that I inherited when I bought my GTX years ago, I attempt to do a head swap as cheaply as possible - mostly because I don't have funds to do this engine over properly.
As a reminder, the "subject" consists of a 440 of dubious history; I have in the past determined the block to be a '75 low compression deal but stuffed with the reciprocating part of the cars' original 440 from 1968 - forged crank & rods. It has some manner of flat-top pistons in it that don't come anywhere near the deck.
No ring grooves to speak of in the cylinders and they're pretty smooth, so the previous (now deceased) owners' claim of a "rebuild" may sort of be true. Kind of. A little.
It wiped a Mopar puprpleshaft cam rather quickly once I got it running a couple years ago (I blamed it on synthetic oil in a "new" motor), so I swapped in a Comp Cams and lifters of mild design - a couple steps up from stock, that's about it.
It ran ok for a while, then went south on me again about a month ago. I found an intake vacuum leak around #8 and when I removed the intake, I found a bent pushrod on #8 intake and a sticking valve... on what was discovered to be 516 heads ('65 361 & 383 applications). Made sense, as previous owner had a '65 convertible back in the day.
Ok, on to what I've done since then:
I procured a nice set of 906 heads from a good friend out in Indiana. He had his man at the machine shop get them all dressed up for installation, decking them enough to clean them up, hot tanking them, replacing some valves that needed it, installing new valve seals, etc.
My buddy literally gave me these heads for the price of the machine shop work + shipping.
Man, I love that guy.
I fetched a set of FelPro PermaTorque head gaskets, A MoparPerformance intake gasket set and MrGasket header gaskets. I also sent off for a new set of Comp Cams pushrods (stock length, a gamble). The rest I am cleaning up the best I can and re-using.
Today was the beginning of the work. Using ScotchBrite 320 pads, I set about cleaning the gasket surface of the block (worked really nice!).
Todays' progress pics:
The block cleaned up nice, I thought...top pic is a "before" pic, bottom the "after".
906's looking really good. They put a new set of valvesprings on them for me too!
Great guys...
Got 'em all painted up and put the intake gaskets on them. All the bolt holes have been chased and they're ready to go on the block.
Stock intake is all cleaned up. I put the intake gaskets on there, too. It's ready to go!
Oh, I fetched a new set of Edelbrock intake bolts for it, since mine were all hodgepodge junk.
Passenger side on, bolts all torqued. I went ahead and got the header on there and installed at this point, since I knew climbing under the car would take a lot out of me.
Great guys...
