It's this one here:That's a good idea. I've never seen one before. I never did like the plastic or copper line.
Thanks! It's been a long road, both with the car and with my health - almost 6 years now.Looks and sounds good, nice car.
Thanks, I'd been thinking about something like this for a long time, I didn't know that was available. Thanks for the link.It's this one here:
https://www.summitracing.com/parts/RUS-640720
I did have to pick up an adapter for the back of the gauge because it was a smaller inlet size, though. The part under the hood was a simple pipe nipple I put in so as to get clearance for that end of the deal. I have a thread up on here somewhere where I show some pics of the install.![]()
Yessir.Thanks, I'd been thinking about something like this for a long time, I didn't know that was available. Thanks for the link.
Much appreciated.Looks and sounds good, nice car.
Yep, I actually did just that.Don't remember the math but if head/block are cut the intake side of head needs cut a little for int.mani. to still line up correctly. Also one little trick to use in holding pushrods when installing rocker shafts was to straighten a coat hanger and lay it on intake side of rocker stands & all the rods are right there.
Well, I am honored sir!From one shadetree mechanic to the next, very nice, looks and sounds great. You have now graduated to...???
Senior Shadetree Mechanic?
Thanks.A little late but for next time. Carb cleaner cleans the brown baked on stuff much easier than brake clean with little scrubbing. Prefit the intake w/o gaskets. If the bolt holes line up perfect w/o the gasket it may need to be cut. Ovaling the holes slightly towards the top will help if it's not to severe. White Teflon thread sealer will keep oil from wicking up around the intake bolts.
Doug
Yeah, I think I'm going to do something similar if I ever have to pull the intake off again - and you know I will.Glad you got it back together and running again. I use a cast aluminum Indy valley cover with Felpro intake gaskets.
Not sure about a stock intake, but I'd say probably not. They're made to be used with a single plane manifold. I machined off part of the bottom of my Performer RPM manifold, heat crossover. I'm using Edelbrock heads that don't have the crossover passages so it didn't matter. I've seen a sheet aluminum cover that has a depression to clear a dual plane but I don't remember where. Possibly Mancini.Yeah, I think I'm going to do something similar if I ever have to pull the intake off again - and you know I will.
I wonder if any of those valley covers will work with a stock intake?
Yep, they have them among others and yep, most of them say "no dual plane intakes". The one you're referring to has that sinkhole looking part in the middle and says it will work with some dual planes, but doesn't mention the factory ones specifically.Not sure about a stock intake, but I'd say probably not. They're made to be used with a single plane manifold. I machined off part of the bottom of my Performer RPM manifold, heat crossover. I'm using Edelbrock heads that don't have the crossover passages so it didn't matter. I've seen a sheet aluminum cover that has a depression to clear a dual plane but I don't remember where. Possibly Mancini.
