justavillain
I was driving my A12 a couple months back and when I turned on the headlights I had 1 dim but useable, 3 super dim, high beam or low didn't change much. They are fully lit but they are not worth anything driving wise. I believe all of them are replaced with Sullivan (Sylvania?) ones not long ago I know for sure 2 of them 1 on each side I replaced apx a year and half ago and it was ok then. the dashboard is lit to its normal brightness. the plugs are tight and the grounds are in the factory location but I did not check them yet. I was looking to see what the hive mind may have other than a ground and hot wire. If I remember correctly the headlights are powered by the dash board and curious if something in there could be the issue. the car is far from factory as far as most of it goes so tracking down wires might be a bit of a trick but I do have a multimeter, power probe and their tracer and a little bit of knowledge of these cars if that helps!
I can grab a photo of anything needed
