I have the UTMOST RESPECT for all A12 cars, because of what they are, what they were in the era they were new in, how they perform, and they are beautiful!
Without the A12 there may have never been any V-Code cars, like my 70 V-Code Roadrunner.
My car is a much better way to have a 440 6bbl car FOR ME because of my price range when I was shopping, they were asking $58K if I recall correctly (I paid less), real V-code but 71 block, but all 6bbl rods, crank, pistons, stock bore, yada yada...
I have a couple of friends who are brothers and they both have 70 Roadrunners and "do the factory new" thing. That would make me crazier than I am. I like to do performance, handling, comfort, and some esthetic mods and if it was an A12, well, there would be no way.
My point is (other than to praise the A12 and in their own right V-Code cars) to say that a less than original A12 may certainly have a happy home, if the price is right and the buyer finds in that particular car what
they are looking for. I guess if I had found an affordable A12 that was a long way from "correct" I may have given myself the same latitude that I have with my V-code, but it's more likely that I would have always either been pursuing a return to "original, as new, complete" versus being mindful of my V-code's unique pedigree and inherent value, but allowing myself to make it like I want it to be. Easier to do with a V-code than an A12 in my opinion, and because of what I want to do, a LOT more fun and no more or less expensive than the "quest for as new original". Maybe the OP can find an A12 or V-code that suits him.
I'm certainly blessed I found mine.
I just ordered U.S. Car Tools subframe connectors for my car. It's in the process of having a Wraptor serpentine belt and accessory system, Borgeson power steering, Vintage Air, Hydramax hydraulic throwout bearing and HitMaster launch control system, Wilwood 6 piston caliper 4 wheel disc brakes, line lock, Calvert split mono leaf springs and sliders, rear double adjustable Viking shocks (like the front are) QA1 K-member and front suspension system with SPC UCAs, Dakota Digital gauges, Assassin traction bars, Strange aluminum diff cover, and a high RPM/high HP&Torque compatible chromoly steel driveshaft, Strange 1350 chromoly steel pinion yoke and caps, Cold Case radiator all installed. I also put the deposit on a redesigned Bill Mitchell aluminum block that I'm building out to a 541 cu in appx 700 HP and torque boulevard bruiser mill.
It already has a Passon Performance a855 5 speed (I kept the 18 spline a833 as a backup), and I swapped out the 3.54 Track Pack gears for a set of 4.10s. The bench seat was sold, replaced by Scat Procar bucket seats, and I intend to buy a N96 style hood with a "power bulge" or cowl that is tall enough to accommodate the N96 airbox and scoop to replace the N96 hood I have now, which replaced the original NON-N96 hood. All of the "hood hoopla" is so I can run this Weiand 6bbl intake and have it fit underhood with the N96 gear.
I have no shame doing this with my V-code that was some distance away from being "as new, original" when I got it, and BOY OH BOY is it a blast to drive, and in the next year or so it's going to be downright TERRIFYING to drive.
Bottom line, the "V" will always be in the VIN, so it will always have some degree of added value because of that.
