A727 problems?
joe34
7:47 AM
The Salty City in Utah
A727 with trans brake manual reverse shift pattern 5000 stall converter.
All electrical ok from trans brake switch to trans brake sender.
Will not go in to reverse when trans brake switch is activated .
With the driveline disconnected from the diff. cannot turn the drive shaft
in neutral locked up.
When driveline was connected to the diff. you could not push car in any gear or
neutral.
Could the solenoid be bad in the trans.??
