Mopar4Speed
Hi All,
So my transmission is making a heavy vibration when decelerating or coasting but hardly any to none on throttle with vibration getting worse over 45mph. I removed the inspection cover to find it leaking from the input shaft retainer. Safe to say that i think the input shaft bearing is bad. Has anybody been able to pull the bearing out the front and replace with the trans on the bench without opening the case and dissembling the entire case? I had inspected the trans prior to putting it in the car and everything looked like new. It shifts perfect throughout all the gears and is super smooth, it would be a shame to dissamble it completely.. The trans in question is a 23 spline, iron case 833 from a 73 challenger. Any advice regarding the bearing removal would be greatly appreciated.
