LowBikeMike
Would someone with a 69 w/factory AC be kind enough to pull the two wires from their AC time delay relay (found under the right hand trim panel at bottom of heater box)and measure the resistance between the two terminals on the relay without vacuum applied?
I'm working on putting my AC wiring back together properly and have figured out how this relay works, but mine is showing close to 75 ohms at rest, then infinite once I apply vacumm and the timer kicks out. I think the infinity reading is correct, but I don't think it should have 75 ohms to start with, I cannot find any source that gives any specs.
Thank you in advance. I would also be interested in purchasing a good used AC time delay relay for a reasonable price.
