Industrial applicationsA screw compressor is NOT for the car restorer or hobbyist! The motor runs all of the time and the
compressor loads and un-loads constantly. Too much money, and synthetic oil and filters will drive
you to the poor house.
my buddy has a 5 hp upright Ingersol Rand from Tractor Supply and it's gone through 2 motors also...last time I was in there they were carrying DeWalt alsoCampbell Hausfield 5hp two stage is what I have now and this is the second electric motor failure.
If both motors were Baldor, I’d check friend’s wiring to make sure the startup amps are well supported (at least 30A) Baldor motors are pretty reliable but I suspect the Tractor Supply IR uses cheaper motor. A real 5 horse Baldor motor costs more than most guys spend on their Compressors. Also , the Tan IR’s are made in India, the Gray ones are made in USA.my buddy has a 5 hp upright Ingersol Rand from Tractor Supply and it's gone through 2 motors also...last time I was in there they were carrying DeWalt also
IMO.....I always spec's SULLAIR with the 24kt lubricant, it is a screw machine. I used two 500 hp SULLAIR machines w/ 4160 volt 3 phase motors in parallel for the entire plant, with refrigant-dessicant dryers as I needed -20°F dewpoint air for instrument air. ALTHOUGH Ingersol-Rand makes an equilvant machine. Atlas-Copco makes an oil-less machine ....but a 2 stage, with an innercooler, recriporating machine with a 240 volt single phase motor, 5 hp minimum and a 60 to 80 gallon tank (either vertical or horizontal...depending on space available) would be best for home or light commercial use.....use synthetic oil as recommended by the maker. Garder-Denver is another good machine. Just my opinion......Industrial applications
