Air Conditioning Templates?
dodge68charger
9:04 AM
Washington
Would Like To Put Air Conditioning Into My 69 Superbee.
The Car Did Not Come Factory With A/C
and I Don't Really Want To Put The
'Under Dash' Unit In If I Don't Have To.
Heard Good Things About Classic Auto Air
Is There a Template To Cut Out The Firewall/Dash Holes That Anyone Knows Of To Use The Factory Style System?
Thank You
None that I know of. I thought Classic had a template for their systems? If not, then you might have to get creative
I made a cardboard template from a factory AC unit. The problem is locating the holes accurately against a non-AC firewall. You can get close using photos from web using the fire wall suppliers pics but I’d like to be more accurate. The best case scenario would be to find a AC car without an engine you could measure and find common reference points.
I’m going to take some dimensions / make a template this weekend if it works out. I tried taking measurements on a car with the a/c unit installed and I wasn’t comfortable hacking into my firewall with those dimensions. The car I’m looking at this weekend is an a/c car with no a/c unit installed just a bare firewall. I’ll let you know if it happens.
Non A/C
A/C
MM1979 - 1968-70 Dodge, Plymouth B-Body; Firewall Panel; with AC; EDP Coated
