Can I get it on that deal?----
Lets do it for Pinks Mike!
Doug
OK----
LOL...you would have to go 10.157 not to lose your car.....I will.trade you even though. Love ur car--
I've reconsidered my comment, no deal on pinks but the Hoosiers and other items are shipped.
---LOL...you would have to go 10.157 not to lose your car.....I will.trade you even though. Love ur car
good info in this video
how the air enters that carb is more critical
sharp flat edges aren't good for flow or HP
the old velocity stack theory "still" really works
it's a big block cheby on the dyno, but the airflow is what counts
more than the actual air-cleaner, the base makes all the different
you will...for sure---
Thanks, same with your car Mike.
Plans are to spank that 10.15 this year too. With one hood or the other. LOL
Last pic looks identical to mine. Used moroso foam on mine .---
My fibreglass base ranks about the same as your hold down Frank! Some pics for proof. Lol
I made a mold out of plastic board or whatever it's called. Then I taped it completely up with packing tape and got out the fibreglass.
When I was done the packing tape wrinkles showed through. Lol. But it matches the bottom of the hood.. Haha
Picture before being secured to the air cleaner base.
The dip in the rear is for the hood structure.
I used some A/C foam from the hardware store for the seal.
I can run with or without the air filter. The plenum is held down firmly with the hood when closed. Posting these pictures though I see that a hold down would be a good idea when not running the filter.
---I agree. Look at the bells on the 63 - 65 Max Wedges and Hemi's.
I wonder if turning vanes in the scoop to bring air straight into the top of the carb would be beneficial .
View attachment 584032 View attachment 584033[/QUOTE
That's a Quick Time? What about a K&N stub stack?---
Yes it's about as good as it gets with one of these bells.
Sealed up to a hood, how hard can it be...
---That's a Quick Time? What about a K&N stub stack?
You need to open a fabrication business my friend..A new 16" K&N top air filter element showed up the other day. This should help during those dust storm days at the track.
Been working on another plenum now that can be used on calm days, if that ever happens..
Starting to take shape. Once sealed tight to the hood this air bell should work quite well.
---Back in the 70's Tom Hoover said a scoop opening of 30 sq. inches was enough. He was talking about Pro Stock where scoops were off the surface of hood. I always wonder if a big scoop, 2nd picture might slow you down. Did you ever try to make opening smaller?
