What Dvorak sells is the arm on the carb, It is only needed if you are racing??? It is not needed to make the carbs work on your car. The rest of the linkage is the same. Don't waste your time and money searching for the arms.Yes I knew there was a clearance problem but I thought that even if I cut them that the carbs would not hook up to the MW linkage without the replacement linkage, but I have not been able to find that linkage from Dvorak anywhere.
Do you know where I can find a link to it? Thanks
