Garys1969RR
My 67 Satellite with a 400 engine has a belt squeal that starts after 3-4 minutes of running. The alt bearings were rough so I replaced the alternator. No help. So I put on another water pump, and replaced the cast iron W/P pulley with a good steel one. Still no change. I drove the car 1200 miles from Ohio to Colorado, and cant hear the sound on the hi way, but at slow speeds driving around town you can. Its really annoying after awhile. Could it be the 4.99 Valu Craft belt I put on it? The original belt made the same noise, and it was a ribbed design on the pulley side. Pulley Alignment is perfect, and the bottom pulley looks to be cast iron. Could the noise be coming from another source such as the timing chain or cam? Would belt grip/dressing help?
