Tom Patchett
Problem is that since owning this Charger, have had a constant battle with overcharging the electrical system. It caused me to burn down a battery on Power Tour in White Plains, Georgia. Decided to fix it. Normal driving was showing 16.5 volts as confirmed by testing. Would turn on the cabin fan to lower the voltage or in some cases the lights. Was getting about 9 months per battery.
Traced the problem easily to the positive wire going to the regultor on the fire wall was showing as a ground. Would read a constant 2 ohms on the multi meter. Then traced it past the bulkhead connector into the cabin. So far, easy. Got complicated.
You can skip this part, but let me explain exactly what vehicle am working on. This is a 1972 hardtop charger. It has factory air, Big Block, auto, ralleye dash, hide away headlights. Have rewired the power feed from the alternator to the starter relay. The distributor is an electronic MSD and the ignition 1 and ignition 2 wires are joined together. The regulator is a mopar 2 wire on the firewall.
Back to the wiring. The blue with white stripe is a hot feed that goes many places. As I am lying under the dash checking various items, decided needed more access and pulled the dash. Not the best idea.
Now had a real rat's nest. Nor could the errant grounding problem be found. Upon a couple of friend's advice looked to eliminate unnecessary relays and systems until it cleared
Soultion: Clip blue wire with stripe at the seat belt relay behind the glove box. Problem has vanished. Blue wire with stripe is testing good. Not an elegant solution, but a solution. Just fixed it this morning.
