megaivtes
Checked the FLD wire and no volt. on either end with IGN on.Try disconnecting the field wire from both alternator and regulator. Turn on ignition power and test if either end of the wire has voltage. It should not have any.
If it does, use electrical tape to cover the terminal ends, and run a new wire directly from regulator field terminal to alternator field terminal.
Also, Looking at your chart, you also have excessive resistance drops in the wiring. Check bulkhead connections.
I did notice improvement after noticing new VR had a wider bracket and was landing on some weld. I swapped to old VR, cleaned off more paint behind bracket. I also cleaned dried oil deposit on BATT GRND at cyl. head.
Batt. volt. running was now 14.8-14.9 and at fuse panel I had 14.7. That's a big drop at fuse panel from previous 15.45.
Also, I saw 14.4 -14.5 at the IGN side of VR.
Do I continue chasing better grounds?
