Flash
Copy I'll check resistance on the ground. Can I check the voltage regulator or can only swap it?I don't think that's low voltage but would check the ground on the engine if you are having problems then change the voltage regulator. It's also possible to have blown a diode in the alternator (back half of the case) but I don't think that's the case in this situation.
