Bee1971
My third summer on my 383/432 Stroker - First motor with Aluminum Heads
Engine has been pretty much flawless other then some ignition issues
Anyways Edelbrock E Street Heads 75cc / Weiand Dual Plane 8008 Aluminum Intake
Edelbrock AVS2 800 Carb
Running the Fel Pro 1214 Valley Pan along with the fiber gaskets
This summer I noticed oil drops on my valley pan under the intake manifold
Things got progressively worse when I noticed the top fiber gaskets under the intake looked like they where moving up towards the valve covers
Anyways I pulled the intake manifold last night - All the ARP bolts where tight snug (25 ft lbs torque)
Those top two fiber gaskets on the valley pan where not only moving but also ripped in places by the intake runners - The bolt holes on the top fiber gaskets where elongated
Bottom two fiber gaskets under the valley pan on the aluminum heads where perfect condition
I know a lot of guys don’t use these fiber gaskets period , just the tin valley pan alone
I guess I have always let the Intake Manifold fit decide on fiber gaskets or not , two / four or none
But everything fit really nice honestly , and the intake manifold bolts started fine when I built the motor
Block was just decked , cleaned up from the machine shop per my request , as I knew running these 75cc heads my compression would bee 10.5-1 already
Anyways , I got everything cleaned up today
When I drop the intake manifold dry on the heads without any gaskets or valley pan , intake fits and looks really nice - Corners of intake are not hitting anything , not even close . The threaded holes on the heads are sitting near the top of the intake manifold holes for the bolts
Anyways going back to the expanding / contracting of aluminum heads and aluminum intakes
Debating on what to do next putting this back together - Suggestions please , Also wasn’t impressed with the Permatex liquid white threaded sealant for the intake manifold bolts and weeping oil
Combo effect with oil on Valley Pan and looked like oil in intake runners on heads
Anyways sorry for the long thread
