- 10:41 AM
- Nov 22, 2010
- Muroc Dry Lake Bed
Yup, exhaust leak,,
Sounds like an exhaust leak
Great vid of the sound. My pop used a long screw driver to his ear for internal diagnostics. Also, would partially block the exhaust tip with a rag to increase the source of the leak upstream.
Thank you. No cover in there, tried to put one but the bolts were hitting it straight away, not a chance.If not an exhaust leak check that nothing is hitting your torque converter cover, like a torque converter bolt. But doesn’t sound quite metallic enough for that so exhaust leak is most likely. If you have exhaust manifold gaskets I’ve seen entire pieces of them break loose and get blown out a few times.
That is a bloody good and simple idea.I agree. It does definitely not sound like a knock to me.
I had the same problem and used a smoke machine like used in nightclubs to diagnose the problem.
Just shoot the fog into your exhaust tips on the back of the car and see where it comes out on the way to the engine.
You can use something like this: Z-3000II Fog Machine - Antari Lighting And Effects (Or also the cheaper Z-1500II)
This generates a lot of smoke so you will be easily able to tell where it comes out.
whats the movie?Best war movie ever made.. By miles.![]()
Das Boot: I’d call it the best one of the sub flics.whats the movie?
Das Boot as stated above.. it's in german and 1/4 way in you won't even need the dialog.. it's done so well you can smell the inside of that boat, even sat through the 5+ hour directors cut.. was amazing (it was first made as a mini-series then re-cut into a long movie)... ok.. back to exhaust leaks nowwhats the movie?
ATF produces the same result, too.A way that I have found exhaust leaks is to squirt some diesel into an engine at fast idle. It will make a ton of smoke, and should show where any leaks are.
Simpler is a smoke bomb from a fireworks supplier. We used them to find leaks in sewer vents in walls inside of houses.I agree. It does definitely not sound like a knock to me.
