AMD 3 inch wide inner wheel wells
skidoojim
3:56 PM
Layton Ut.
69 charger I'm installing AMD 3 inch wider inner wheel wells, rt. side fits pretty good the original tooling holes line up pretty good the left side is off quite a bit, I would like to know if anyone else has or is installing these and what kind of problems they have had?
I would check out Chris Birdsong's youtube channel where he repaired the inner wells on Frieburger's General Mayhem Charger (among a TON of other stuff):
I think he's also a member here so you could reach out to him @smb03 for some advice...
My holes did not line up either on the AMD inner and outers. as long as everything else looks ok, I would not worry about it.
When I made a set of wheels for the rear of my 71 Cuda, the left side wheel fit just fine with the stock offset. Decided to make sure it would fit the right side just as good. It didn't. One of the reasons I checked is because I bought a piece of rear trim (SE trim?) that ran across the the back of my really nice original paint 70 Challenger and it was 1/4" wider than the car was. Thing is it fit my 70 Challenger ragtop perfectly. Neither car showed any signs of being wrecked and repaired. Anyways, I had to adjust the offset of my right side wheel about 3/16ths inch to make sure I had room to spare on the leaf spring. I also checked the car for square and it was on the money and the rear was within 1/16th inch with the fronts. Our cars are NOT perfect from the factory. Body tolerances are tight these days and the cars back then were not.
luv the 3" wider AMD inner panels
on some builds where I need to stretch the opening for much bigger rears, I've used trailer fenders back to back. Being a Mopar guy often requires us to be resourceful
