Turbobus
I get that, it’s a load dependent piece of equipment just like you explained. The problem is at idle 850 rpm it goes to discharge with only the ignition being used, no other loads placed on the system, no fan, lights etc. the alternator I ordered claims 100 amp and more than 30 amps at idle, so right now I’m doing the fleet bypass per 72 GTXRoadrunner excellent diagrams. So when I call the manufacturer of this alternator I can explain that the harnesses are new with the factory connector delete 60+ amp wiring diagram from Chrysler and simplified for idiots by GTX. I’ve ohmed out all grounds and they seem fine, same as leads, maybe barking up the wrong tree, could be regulator but tried three others, maybe I need an arborist to show me to the right tree bark atKeep in mind...it really doesn't matter what the rated output of an alternator is, if your car isn't demanding that amount of current.
The alternator will only 'get excited' enough to provide the current that your system is ***** for...in other words, you could strap a 200A alternator on there but if your car's total demand is 40A, the alternator will only squirt out 40A.
Thanks for your help, if you have other suggestions please bring them up, Thanks
