TopBanana72
Thanks in advance for any opinions or experience or what you would do if you were me. I'll be as precise as possible.
THE CAR: 1972 Dodge Charger, base hardtop, all original equipment 318 car, 904, 8.25, 2.71
THE PURPOSE OF CAR: This is my highway cruiser. It will never see a race track, but I love it for cruising. Looking for a bit more performance for highway passing, coming up to speed, some "spirited" driving if you will. Nothing crazier than that. Don't care about burnouts with this car.
CURRENT STATE OF CAR: It is a 128,000 mile tired engine car. I removed and disassembled the engine and sent the block and crank to the machine shop. It's done with a .30 overbore. Everything else checks out fine (Mopar goodness). Rods are good, main caps and crankshaft great shape too. I will be keeping the stock rods and crank. I also do not want to change any of the other driveline components like TQ or rear gears at this time. Probably will never re-do an engine for this one, so I'm being careful with the planning here as I want it to last a long time and enjoy it on the open roads. Planning on driving it to Carlisle this summer.
WHAT I HAVE (and would like to use):
KB167 pistons to replace the old ones.
Existing Edelbrock Performer 318-360 intake.
Existing Edelbrock 650 AVS2 carb.
Existing dual exhaust (2.25" off stock manifolds, no crossovers, Flowmaster 40's).
New distributer (stock style, Chrysler electronic ignition replacement).
Existing valve train (rockers, shafts and pushrods all look good).
THE QUESTION:
What heads and cam should I get for the engine? (I don't intend to use the old heads - too worn out.)
THANKS!
THE QUESTION:
THANKS!
