Here’s my 318 build.
Plan is to use most of what I have and as usual it’s a budget build. The goal is a good performing street ride in my 66 Coronet. It’s got 3:23’s , 904 with the A&A low first gear set. Shift kit, 5k governor with the higher shift point 1-2 shift spring. advertised 3k street rod converter. Not looking to tear up the streets but a fun car that’s pretty quick, can run on the highway, has AC and runs on pump gas.
I have the following parts that I can use:
302 heads cut .050 to 54 cc, larger 360 valves, port/polish, blended bowls, matched to the intake. PC seals and new springs for the cam. 273 adjustable rockers and custom length pushrods.
I have a Summit
CHRYSLER Summit Racing SUM-K6901 Summit Racing™ Classic Cam and Lifter Kits | Summit Racing Duration 276/288, Lift .441/.441 cam but also considering the Lunati 10200702LK VooDoo 702 stick Duration 262/268, Lift .475/.494
600 Edelbrock carb and LD4B intake
Mopar Dist with chrome box recurved and a blaster 2 coil
I have a complete rebuilt 273 short block that I can sell or use the polished forged crank reworked rods with arp bolts in the 318.
The 318 would be bored .030, line honed and the deck cleaned. My plan is to use a set of the KBPKB167KTM.030 or another recommend piston and since they are around .015 above the deck use the Fel-Pro 521SD head gaskets.
I would prefer to run exhaust manifolds to keep with a somewhat stock appearance so looking for recommendations. I have a late model LA series set but they are 2-1/4 pipes and the rest of the exhaust is a 2-1/2 mandril bent system with a cross over so I hate to choke it down. A nice set of 340 ones are out of the budget. Might look at a set of the short style headers if I can’t find a suitable pair of irons.
So, this is the basis of my plan! Please provide any thoughts or recommended changes. Also, if anyone is near Manchester MD 21102 that’s selling a 318 short block, please let me know.
Thanks,
Wayne
