I just ran that graph through a torque to horsepower calculator and it comes up with 300 HP even at 4500 and 5000 rpm. If anything the 700 might do a bit better because of slightly more intake duration and a little higher lift.
You want Torque. Throw a Dana 410 in it.I have bought a 1966 Charger with a 361, automatic and 3.23 gears. It has stock exhaust manifolds and a stock 2 1/4 exhaust system into 2 inch tailpipes. It will have a Performer 383 intake, a 625 Street Demon spread bore type carburetor and MP electronic ignition. It has PS, PB, and factory A/C. I have an extra set of 2.76 rear gears sitting on the shelf. The car is not in my garage yet (long story) so I do not have access to do a compression test or assess the parts that are in it. I have driven it, and as far as I can tell the long block is all stock. Not even sure if the heads have ever been off, I assume they are still 516's.
My question is what would be a good cam to upgrade performance, especially torque? I am wondering if I have to be a little more conservative with the 361 versus a 383, kind of like a 318 versus a 340? My goal would be an honest 300 horsepower and as much torque as possible, which will cruise at 2000-2500 rpm (depending which gears I use) and get decent gas mileage. I just sold an 11 second street car, now I want a cruiser.
I’d go with the 701.
Actual cam card can be found at Lunatipower.com, look up the cam.
