I'm going to order a CR21A tank for my 77 Cordoba. Will the existing fuel sender work in the smaller tank? If not does anyone no the part number to the correct one.
The straps are the same. The sender mounting on the c21a is at a slightly different angle so it is necessary to bend the pickup tube and float down.
Hopefully it will read full when I full it.
