Dusty Dude
Anybody know how to stop the telescoping antenna tubes from rattling and buzzing short of removing it from the car? It's on my 69 Coronet.
Thanks for the idea. The problem is that when its lowered completely each section rattles against the one it slips into. Most likely no way to stop it. Just thought I'd see if anyone had experienced the same thing.Adjust it to the height you
want and apply shrink wrap
to each joint. 3/4" on
either side of the joint works
well. (Been there). You will
lose it's telescoping
functionality.
The shrink wrap will hold itThanks for the idea. The problem is that when its lowered completely each section rattles against the one it slips into. Most likely no way to stop it. Just thought I'd see if anyone had experienced the same thing.
Thanks All
Agree, Dadsbee. I was onlyI've never seen an antenna so worn out I could hear it rattle over my engine. Buy a new one if grease won't fix the one you have and just thread it in. No need to replace the lower mount if it's OE...
