Had a neighbor cover his camper last year and squirrels got into the wiring and did a lot of damage. He says he will not cover it again for the winter.
Man, I saw the effects of ArmorAll 50 years ago!! So, that crap is still just as bad as it was back then??NEVER USE A TARP.
You will turn your RV into a terrarium. Moisture gets under the tarp (not a "maybe" - it DOES), gets trapped, and turns into a steam bath because it can't escape. You will rot your RV from the inside-out if you put a tarp on it. That is a decade of experience in RV sales and service talking - it's a guarantee that time under a tarp, will rot your camper.
Now, breathable covers are fine. Think "Evolution 3 car cover", the quilted material. They work fine, because the moisture can vent back out and the camper will dry. However...you really don't have to cover it. What is your thought process for covering? You have a white fiberglass camper with vinyl decals on it, and I presume a rubber roof. They're designed to be out. Worst that could happen is the white 'glass might "chalk" some, or your decals might fade some, but that's about it. Covers don't keep snow load off of them, and they don't really keep dust/dirt off them either because they breathe, and that allows moisture to get OUT...but also allows fine dirt particles to get IN.
There's a product called "Reliable" you can use to keep it clean - once a year (or before every camping trip) simply mix some in a bucket of water and use one of those car wash brushes, and it'll get everything off the sides - dirt, mold, algae, streaks, all of it. No heavy scrubbing required. Works on your awning fabric as well. Wash, rinse well (don't let this stuff sit on the camper, and do NOT use it on your car!!), and go camping.
Maintenance wise? Seal your roof and all your corners and seams (window frame seams, luggage door seams, etc), every year. Pick out anything loose (a 'softer' wire brush works well for this), clean them well, and re-seal. Roof gets a self-leveling sealant (like marshmallow fluff) - put it on thick, let it settle in. Sides get silicone sealant. Use a cleaner/dressing for your slideout rubber gaskets to keep them moist. DO NOT use WD40 or ArmorAll, it will rot the seals.
But, with as easy as it is to clean with Reliable...really, no reason to cover it. If you had a full-body paint motorhome, that would be a different story, but white 'glass with decals...I wouldn't sweat it. My car trailer sits out, doesn't leak, I clean it once in a while with Reliable, and it does just fine - and it's basically an RV without an interior: awning, windows, white aluminum sides, self-level sealant on the roof, 15k a/c... Same for my equipment trailer (silver, not white). Hit 'em with Reliable when they get dirty, just a light rub with the car wash brush on a stick/handle...and they're good to go.
I don't mean to hijack the thread about covers, but just some experience on choosing campers.Subscribed!
My wife and I had a Coleman pop up camper when the kids were young (with A/C and a slideout, believe it or not!). My wife is retiring in November so we are looking to get a camper next year. We are gravitating towards a "couples camper" but definitely want a slideout. We have been looking at various models so I am in learning mode - hoping I can learn something here as I will need to store mine outside as well.
The best thing to scrub out the black water tank is dump bags of ice in it literally right before you leave with some water. It will clean as it sloshes back n forth while driving. Then all you have to do is drain it. This is also good for cleaning up the gauge in the tank if its hung up and reads full all the time.While we're on the camper subject.. what's the best thing for cleaning out the septic tank. I heard throw in a half a jug of bleach and drive around?
Never thinking of a tarp. I want one more for sun and leaves, I literally live on top of a mountain in the woods. The breathable one would be ideal. After seeing what happened to others I will probably put an R/V car Port up next fall. As far as snow we don't get much snow anymore so that is not an issue.NEVER USE A TARP.
Sadly that stuff can happen covered, uncovered indoors or outside. I keep our boat inside and this year when I got it out a mouse had chewed into the top of the seat making a hole the size of a nickel. Pissed me off you can see it on the port side top of seat. I literally just cleaned it outside and inside this morning and put it back in storage before the monsoons hit this weekend!Had a neighbor cover his camper last year and squirrels got into the wiring and did a lot of damage. He says he will not cover it again for the winter.
