Sleep well.
Good work Wayne.Well.. back from an hour and a half drive after putting everything back together. That PCM voltage does the zero hit about every 12 minutes like it's supposed to do that. Snowing and **** out side so I got to make sure traction control works... light blinks and it unpowers what ever wheel it needs to to make you go straight. ABS pulses away in a lock up. Drove it like a nut... no warning lights.. no AT light.. no transmission hammer everything working perfect.
I might get a better sleep tonight, but I'll be filling it with gas and driving it half the day tomorrow before the Daughter gets it back with my Granddaughters in the back seat...
Thanks to those that have helped and tried to help. Even if that PCM voltage drop is a Mazda special, it at least got me to start looking for a cause !!!
I didn’t read closely enough that it was AWD.Not sure where that came from Ian, but this little Mazda CX-3 will go damn near anywhere, it's AWD. She's never been stuck and the lazy husband has never even shoveled their laneway.
I think there is still a place for rear wheel drive cars with studded tires front and back and sandbags in the trunk. My humble opinion.
35, he keeps it up he may not see 36. Time to get her practicing again...how old is the lazy husband?![]()
Cooy, Ranger possibly Hiawatha?35, he keeps it up he may not see 36. Time to get her practicing again...
Now to tackle why her heated seats don't work ......
Exactly why I took it "under my arm". Moffat Mazda would have put a transmission in it and it would still have the same problems !!! With her on maternity leave with a 2 month old and a 28 month old no way that I was letting that happen.What's your billing rate? Her bill is gonna be HUGE...
It's unfortunate but cars with minor real problems get scrapped cause at a shop rate a repair like this could easily be more than the owner is willing to spend... Cause after all, until the problem was found it could have been a ECM, a transmission, sensors..... How far do you go before the customer cuts their losses...
She's lucky to have a dad that cares and has the skills to sort it out... Good on ya..Exactly why I took it "under my arm". Moffat Mazda would have put a transmission in it and it would still have the same problems !!! With her on maternity leave with a 2 month old and a 28 month old no way that I was letting that happen.
Well 3 hours of driving it around and I can sleep well knowing I did the best a Father can !! The voltage spike to zero on the PCM was a scanner anomaly, as it only does that while also monitoring the alternator output at the same time. If you monitor it, or any other voltage solo it's darn near a flat 13.9 volt line for hours. Now to tackle why her heated seats don't work, yet the indicator switches that show they're on do. Hopefully just a relay...
View attachment 1585543View attachment 1585544
Definitely weird, but based on the girth of the wire, compared to the others in the same plug, that was the main power wire to the transmission. Everything else in the fuse box looks like new, except that pin pair.Did you come up with a hypothesis on why the corrosion sucked into that 1 terminal?
Some older vws used to leak coolant into the dash through the wiring..![]()
