Bee1971
Flat Top Pistons with no valve reliefs I would assume ?
What you really need to find out is , pulling your old heads off first and measuring , finding out how far those pistons are in the hole
383 Sealed Power Forged Flat top pistons .015 in the hole , no valve reliefs
.039 Head Gaskets
Mopar 284 - 484 Camshaft that had been running within that 383 / Factory 906 heads for over twenty years
Forward last summer - Installed
Eddy E Street 75 cc heads with a larger intake and exhaust valves over a factory head
Everything else the same
Kissed two intake valves on those flat tops within 200 miles
Bottom line running any flat top piston with no valve reliefs , really limits your camshaft selection with any larger valve head
Now I have a 432 Stroker / 440 Source Kit within that same block , same Eddy E Street 75 cc Heads that has not seen the street yet because of WI Winter
.039 Head Gaskets
