MCODECUDA
- 8:01 AM
- Jul 22, 2008
- Sherrills Ford, NC
.030 over 426 with 4.25 stroke.
Good point.As a rule a bigger bore helps un-shroud the valves... The 4.25 isn't much smaller than the 4.32 but big valves need all the room they can get...
If using the TF240's be sure and check closely the Valve to Cylinder Wall clrc on the small Bore Engines ?
Trick Flow advertise 4.310" "minimum" Bore for the TF240's... we've used them lower at 4.28" but it can get REAL dicey given the particular Blocks Cylinder Bank offset... so best Mock-up and check all 8 for clrc if planning the TF Heads ? And even then the Valve shrouding seems to negate the advantage of the 2.19" Valves ? We're seeing damn near the same power on the Dyno using Ported Eddy's.... the TF240's just are NOT shining for us until 4.375" Bores ?
We will be running 440 Source aluminum heads with 1.81” exhaust valves so shrouding will not be an issue.As a rule a bigger bore helps un-shroud the valves... The 4.25 isn't much smaller than the 4.32 but big valves need all the room they can get...
