68gtx
just playing with my 440source 512 kit , trying to measure how far down the pistons are in the hole, but never having put one of these together, do I have the piston in the right way, rod bearing tabs and writing on outside of rod are towards pan rail, I think I have the piston right, better to klook stupid and ask the question that be be stupid and have it in worng... if it matters I am using stealth head as well.. how much clearance are you guys running between the rod cap and oil pump boss on the inside of the block..
![piston.JPG piston.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/124/124835-27bb669be15a2801f5a50fba30fb7874.jpg)
![piston2.JPG piston2.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/124/124834-3d47645c814bf3ef5b5fa243acb2b06e.jpg)
also when getting the block decked to zero deck that would be the highest part of the piston right?which in the picture is at the top side, otherwise that upper part would protrude above the deck..into the headgasket. am I correct?
